Knowledge Base Article
Why do I see my Cyclone III or Cyclone IV LVDS_E_3R output signal being inverted?
Description
Due to a problem in the Quartus® II software versions 10.1 SP1 and earlier, you may see inverted LVDS_E_3R output signals in Cyclone® III or Cyclone IV devices. This may occur if NOT-gate push back is implemented on the output register and the output register is placed in the I/O element. NOT-gate push back occurs when a register has an initial high value, including when Quartus II synthesis implements an asynchronous preset using an asynchronous reset.
Resolution
To work around this issue, perform one of the following:
  • Prevent the register from being placed in the I/O element using the FAST_OUTPUT_REGISTER assignment as follows:
  • set_instance_assignment -name FAST_OUTPUT_REGISTER OFF -to <output pin name>
  • Or, prevent the implementation of NOT-gate push back by removing the initial high value for the output register, such as by removing the asynchronous preset.
This problem is fixed beginning with the Quartus II software version 11.1.
Updated 2 months ago
Version 2.0
