Knowledge Base Article
Why do I see minimum pulse width violations for M20K memory blocks in Stratix V I2 speedgrade devices when performing timing analysis using the fast timing model?
Description
Due to a problem in the Quartus® II software versions 11.1 SP2 and earlier, you may see incorrect minimum pulse width violations for M20K memory blocks in Stratix® V I2 speedgrade devices when performing timing analysis using the fast timing model. This problem is due to an incorrect timing model for Stratix V I2 speedgrade devices.
Refer to Table 2-27 of the DC and Switching Characteristics for Stratix V Devices (PDF) chapter of the Stratix V device handbook for details on the Memory Block Performance Specifications for Stratix V Devices.
Resolution
If you are operating the memories within the specification, the minimumum pulsewidth violations can be safely ignored.
This problem is fixed beginning with the Quartus II software version 12.0.
Updated 23 days ago
