Knowledge Base Article
Why do I see Linux prints multiple “unexpected MSI” messages in the PCIe Root Port with MSI design?
Description
In a PCIe Root Port with an MSI design, the PCIe hard IP is connected to an MSI-GIC IP via a pipeline bridge.
When Linux prints multiple “unexpected MSI” messages, you will observe unintended writes happen which do not belong to the MSI-GIC slave.
Resolution
A workaround is to add a second slave to the PCIe master next to the vector slave (MSI-GIC IP). This slave could be a small on-chip memory, a custom register, or something else.
With a second slave and "Automate Default Salve Insertion" Interconnect feature enabled, MSI-GIC will not receive those unintended writes.
Updated 3 months ago
Version 2.0
