Knowledge Base Article
Why do I see intermittent functional problems with the GTS AXI Streaming FPGA IP for PCI Express* after a PCIe link reset?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1, you may see intermittent functional problems from the following functions and interfaces across PCIe link resets: warm reset, Secondary Bus Reset, and Link Disable.
Impacted functions and interfaces:
  • MSI and Legacy Interrupt
  • Application Error Reporting
  • Function Level Reset Interface
  • Control Shadow Interface
  • Completion Timeout Interface
  • VF Error Flag Interface
  • Configuration Intercept Interface
  • Status signals (for example, p0_ss_app_serr and p0_ss_app_ltssmstate[5:0])
Resolution
Cold reset or reconfiguration of FPGA is required to recover from the erroneous state.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 24.3.
Updated 3 months ago
Version 2.0
