Knowledge Base Article
Why do I see Hold timing violations in Intel Agilex® 7 FPGA devices when using PAM4 variants of the Interlaken IP Core (2nd Generation) Intel® FPGA IP?
Description
Due to a problem with the PAM4 implementation of the Interlaken IP Core (2nd Generation) Intel® FPGA IP, hold time timing closure violations may be seen in Intel Agilex® 7 FPGA devices in Intel® Quartus® Prime Pro Edition Software v19.2.
Resolution
A possible temporary workaround for this timing problem is to run seed sweeps so that better timing results are found.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
