Knowledge Base Article
Why do I see functional problems in my clocked video input (cvi) module?
Description
You may see functional(hardware) problems for the CVI module for designs created using the Quartus® II software versions 13.0 and earlier as internal timing violations may be masked by an incorrect set_false_path constraint in the automatically generated sdc file.
The following incorrect set_false_path constraint cuts all timing withinn the fifo.
set_false_path -to [get_keepers {*alt_vipcti130_Vid2IS:*|alt_vipcti130_common_fifo:*}]
Resolution
This problem is resolved in the Quartus II software version 13.0SP1 where the constraint is replaced with the following specific false_path constraints:
set_false_path -from [get_registers {*alt_vipcti*_Vid2IS:*|*_common_fifo:*dcfifo*delayed_wrptr_g[*]}] -to [get_registers {*alt_vipcti*_Vid2IS:*|*_common_fifo:*dcfifo*rs_dgwp*}]
set_false_path -from [get_registers {*alt_vipcti*_Vid2IS:*|*_common_fifo:*dcfifo*rdptr_g[*]}] -to [get_registers {*alt_vipcti*_Vid2IS:*|*_common_fifo:*dcfifo*ws_dgrp*}]
Updated 1 month ago
Version 2.0
