Knowledge Base Article
Why do I see ECC errors on the DCFIFO even when the data output is correct?
Description
When using the Intel® Quartus® Prime Software version 18.1 and earlier with Intel® Arria® 10 devices, you might see error correction code (ECC) errors on the DCFIFO in show ahead mode when the data output is correct.
This is due to the ECC being incorrectly calculated before the data is stable.
Resolution
To work around this problem, ensure that the ECC error is only sampled when data output is valid or when the FIFO is not empty.
This problem is fixed starting with the Intel® Quartus® Prime Pro/Standard Edition Software version 19.1 .
Updated 1 month ago
Version 2.0
