Knowledge Base Article
Why do I see DDR4 Read Capture timing violations in the Quartus Prime software version 16.0?
Description
You may see Read Capture timing violations in your Arria® 10 DDR4 design after upgrading to the Quartus® Prime software version 16.0. The violations are probably due to the final Arria 10 timing models in the Quartus Prime software version 16.0.
Resolution
To resolve the timing violations, enable the Read DBI option in the Memory Topology tab of the DDR4 IP.
Updated 2 months ago
Version 2.0
