Knowledge Base Article
Why do I see color corruption when using the Color Space Converter II IP Core?
Description
Due to a problem in the Quartus® II software version 15.0 and earlier, you may see color corruption when using the Color Space Converter II (CSC-II) IP Core.
Resolution
To work around this issue, use the Color Space Converter (CSC) IP Core instead of the Color Space Converter II (CSC-II) IP Core.
This issue is scheduled to be fixed in Quartus® Prime software version 15.1.
Updated 2 months ago
Version 2.0
