Knowledge Base Article
Why do I see a read data mismatch in the clk_tx_div_khz register when simulating the F-Tile Ethernet FPGA Hard IP by enabling the ETH_SIM_SPEED option?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 24.1, you may see a read data mismatch in the clk_tx_div_khz register when simulating the F-Tile Ethernet FPGA Hard IP with enabling ETH_SIM_SPEED option enabled.
This problem does not occur in simulation when the ETH_SIM_SPEED option is not enabled, and does not occur with hardware.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.1.
Updated 1 month ago
Version 3.0
