Knowledge Base Article
Why do I see a low restricted fmax when using a floating-point adder in Arria 10 DSP block, either with OpenCL or DSP Advanced Blockset?
Description
This problem affects designs targeting Arria 10 DSP blocks’ floating-point mode and when you implement the floating-point adder in DSP blocks. The specification for the adder when fully pipelined is to operate at over 450MHz. However, in the Quartus II software v15.0, you see a restricted fMAX of 298.51 MHz for this module.
Resolution
This problem is scheduled to be fixed in a future version of the Quartus II software.
Updated 3 months ago
