Knowledge Base Article
Why do I see a high Bit Error Rate (BER) when using the F-Tile PMA/FEC Direct PHY Intel® FPGA IP in external loopback mode?
Description
Due to a limitation of the default F-Tile PMA/FEC Direct PHY transmitter parameter setting, you will see high Bit Error Rate (BER) if the external loopback insertion loss is larger than 5 dB. The default transmitter parameters can work well only with insertion loss smaller than 5 dB.
Resolution
With the situation if the insertion loss is larger than 5 dB, you need to add optimal TX analog parameters in qsf file to avoid BER. Future application note will be updated to guide the debug.
Updated 3 months ago
