Knowledge Base Article
Why do I see a Bit Error Rate (BER) of 1 after drawing an eye in the Intel® Transceiver Toolkit when using Intel Stratix® 10 E-Tile transceivers?
Description
Due to a problem with the error counter registers of the Intel® Stratix® 10 E-Tile transceivers, you might see a BER of 1 after drawing an eye in the Intel Transceiver Toolkit.
You might also see the following message in the Transceiver Toolkit message pane.
"Hard PRBS checker error counter has saturated. The checker has been stopped."
Resolution
To work around this problem, reprogram the Intel® Stratix® 10 FPGA.
Updated 3 months ago
Version 2.0
