Knowledge Base Article
Why do I receive the following message: "Internal Error: Sub-system: VPR20K, File: 20k_arch/20k_route_timing.c, Line: 2434?"
Description
You may get this internal error in the Quartus® II software version 1.0 if you have two occurrences of the THIRD_PARTY_EDA_TOOLS variable in your project settings file (.psf).
For example:
THIRD_PARTY_EDA_TOOLS(pci_top)
   EDA_TIMING_ANALYSIS_TOOL = "&ltNONE>";
   EDA_SIMULATION_TOOL = "MODELSIM (VERILOG HDL
OUTPUT FROM QUARTUS)";
   EDA_DESIGN_ENTRY_SYNTHESIS_TOOL = SYNPLIFY;
THIRD_PARTY_EDA_TOOLS(sdram_sdr_ecc_pci_ioreg)
To avoid this error, ensure that the .psf file specifies the THIRD_PARTY_EDA_TOOLS variable only once. This problem was fixed in the Quartus II software version 1.1.
Updated 3 months ago
Version 2.0
