Knowledge Base Article
Why do I receive an error message when generate the FIR compiler?
Description
You may receive the following error message when generating the FIR compiler by using 64 bit of Quartus.
Error Message: java.io.FileNotFoundException: C:\Users\username\AppData\Local\Temp\ncg_886961157648532613\mcv_fir_coef.txt (The system cannot find the file specified)
Resolution
Please go to control panel -> system -> Advance -> Environment Variables
In the User variables:
Please ensure the “PATH” variable is included the “%QUARTUS_ROOTDIR%\bin” correctly.
In the System variables:
Please ensure the QUARUS_ROOTDIR is pointed to the Quartus II version that you are currently using. E.g. D:\Altera\11.1SP2\quartus
Updated 3 months ago
Version 2.0
