Knowledge Base Article
Why do I not see analog parameters value get passed down from GTS CPRI PHY FPGA IP analog parameter GUI selection with the Agilex™ 5 device?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, when you change RX adaptation mode to manual, RX EQ VGA Gain, RX EQ High Frequency Boost and RX EQ DFE Data Tap1 values selected in scroll down menu are not passed down to PMA. When you use register reads for the three parameters, the values don’t reflect the GUI entry.
Resolution
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 27 days ago
Version 2.0
