Knowledge Base Article
Why do I measure high jitter on the “rx_clkout” pin of the F-Tile PMA/FEC Direct PHY FPGA IP or F-Tile PMA/FEC Direct Multirate FPGA IP variant?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4, higher than expected jitter may be measured on the rx_clkout pin of the F-Tile PMA/FEC Direct PHY FPGA IP or the F-Tile PMA/FEC Direct Multirate FPGA IP cores when the CDR is set to lock-to-reference mode.
Resolution
There is no workaround for this problem.
This problem has been fixed in version 24.2 of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
