Knowledge Base Article
Why do I get the error message "Project does not exist" when using the Copy Project command?
Description
The Copy Project command does not function correctly when a project is located in a directory that contains spaces in the name.
Make sure your project is located in a directory without any spaces in the name. You can rename the directory to use a symbol such as the underscore (_) as a place holder instead of spaces (For example, my_design).
This issue has been fixed beginning with the Quartus® II software version 5.1.
Updated 2 months ago
