Knowledge Base Article
Why do I get minimum period timing violation in UniPHY-based DDR3 SDRAM Controller on a Stratix® V device?
Description
You might see minimum period violations on address or command data-path in the Quartus® II software version 11.1SP2 and earlier if the UniPHY-based DDR3 SDRAM memory interface design in a Stratix® V device is combined with user logic that has packed registers in the periphery.
Resolution
This problem is fixed starting with the Quartus® II software version 12.0.
Updated 11 months ago
Version 3.0
