Knowledge Base Article
Why do I get intermittent M20K write failures in my Arria 10 design?
Description
Due to a problem in the Quartus® Prime software version 17.0 and earlier, you may see intermittent M20K write failures in your Arria® 10 design.
The failures are characterized by
  •     Intermittent failures to write a zero
  •     Failures are not timing dependant
  •     Higher Vcc increases the rate of failures
  •     Higher temperature increases the rate of failures
Resolution
This problem is fixed beginning with the Quartus® Prime Pro and Standard edition version 17.1
Updated 1 month ago
Version 2.0
