Knowledge Base Article
Why do I get incorrect results when using the ALTFP_CONVERT megacore to perform floating-point to fixed-point conversions?
Description
Due to a problem with the Quartus® II software, if the input of the ALTFP_CONVER is smaller than the smallest representable number for the chosen output format, the output will give erroneous results.
For example, when doing a floating to fixed point conversion using 32.16 (that is 32 bit width of which 16 bits are the fraction), the smallest representable number is -1.5258789E-5 (0xb7800000).  If one inputs
-0.00000762939453125 (0xb7000000), the result will show -2147483648 (0xcf000000) which is incorrect.
Resolution
Altera recommends to use the new ALTERA_FP_FUNCTIONS megacore for future designs, where the functionality is correct.
Otherwise you will need to range check your inputs an subsitute a full scale output whenever the input falls below the smallest representable value.
This will not be fixed in a future version of Quartus.
Updated 2 months ago
Version 2.0
