Knowledge Base Article
Why do I get inconsistent readings during readback from the IO column delay register in External Memory Interfaces Intel® Arria® 10 FPGA IP via On-Chip Debug Port?
Description
When reading a value from the IO column pin delay register of External Memory Interfaces Intel® Arria® 10 FPGA IP via On-Chip Debug Port you may get a different value once in a few hundred reads.
Resolution
Experimental data shows that incorrect values may occur for up to 2% of reads in the whole span of environmental conditions.
The workaround to this is to read the register N times and only trust the value if all N samples match - if there's a mismatch you should repeat another round of reads. The value of N should be according to the assumed reliability of the read.
Updated 2 months ago
