Knowledge Base Article
Why do I get an error when trying to add an Avalon ALTPLL component in Qsys?
Description
You might get an error, when trying to add an Avalon ALTPLL component in Quartus® II 12.0 Qsys system, using following steps.
1. Open up Qsys
2. Add an Avalon ALTPLL
4. Edit its properties, then click "Finish"
After clicking “Finish”, you may see the Error, along with related messages:
               Error: DLL ("altpll_avalon") not found child process exited abnormally
This is caused by a bug associated with Quartus II Linux 64-bit implementation.
Resolution
On a Linux machine, you can use Quartus II 12.0 (32-bit), instead of Quartus II 12.0 (64-bit) to work around this issue.
32-bit version:   <install folder>/altera/12.0/quartus/bin/quartus.exe
64-bit version:   <install folder>/altera/12.0/quartus/bin64/quartus.exe
You can also use Quartus II 12.0 PC version (either 32 or 64-bit implementation).
This issue is going to be fixed in future Quartus II software version.
Updated 3 months ago
Version 2.0
