Knowledge Base Article
Why do I get an error in the DDR3 with UniPHY memory controller when I uncheck the "Enable Reordering" check box under the Controller Settings tab?
Description
In the DDR3 memory controller with UniPHY version 11.0, if the Enable Reordering checkbox under the Controller Settings tab is not selected and the Starvation limit for each command is set to anything other than 10, then the following error message is displayed:
Error: : The value for 'Starvation limit for each command' is only valid when 'Enable Reordering' checkbox is checked.
Resolution
The solution is to set the Starvation limit for each command to 10 then uncheck the Enable Reordering checkbox.
This problem is fixed starting with the Quartus® II software version 12.1.
Updated 2 months ago
