Knowledge Base Article
Why do I get an error in generating programming files, and it shows as an invalid license for Nios® V Processor for FPGA in the Quartus® Prime Pro Edition Software version 24.1?
Description
As FPGA Intellectual Property (IP) solutions have replaced Nios® V Processor for FPGA for IPs from the Quartus® Prime Pro Edition Software version 24.1 version, you may encounter an error while generating programming files. To resolve this, ensure to install Nios V Processor for FPGA no-cost license before using the below mentioned list of IPs.
Please get in touch with the customer support team for additional information on how to download the free license.
List of IPs requiring Nios® V Processor for FPGA free license:
  1. F-Tile Ethernet Multirate FPGA IP
  2. F-Tile CPRI PHY Multirate FPGA IP
  3. F-Tile PMA/FEC Direct PHY Multirate FPGA IP
  4. Ethernet Subsystem FPGA IP (F-Tile & E-Tile)
  5. E-tile Dynamic Reconfiguration Suite [Applicable only to Design Example]
  6. Serial lite III Streaming FPGA IP [Applicable only to Design Example]
  7. F-Tile Dynamic Reconfiguration Suite FPGA IP
  8. GTS Dynamic Reconfiguration Controller FPGA IP (Agilex™ 5)
  9. SDI II FPGA IP (Applicable only to Design Example)
  10. HDMI FPGA IP (Applicable only to Design Example)
  11. DisplayPort FPGA IP (Applicable only to Design Example)
Error Message:
Error(23714): Can not generate programming files for your current project because you do not have a valid license. Visit the Intel FPGA Self-Service Licensing Center at https://licensing.intel.com.
Warning(115005): Unlicensed IP: "Nios V/g General Purpose Processor Intel FPGA IP (6AF7 018C)"
Warning(115004): Unlicensed encrypted design file: "C:/Users/*” - Intel
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 24.1, follow the steps below to
  1. Obtain Nios® V Processor for FPGA no cost license.
    1. Go to: https://licensing.intel.com/psg/s/?language=en_US (a registered account is needed)
    2. Select Sign up for evaluation or no cost licenses
    3. Select the license needed and click Next
    4. Choose an already existing computer or create a new one (NIC ID of PC is needed https://www.intel.com/content/www/us/en/docs/programmable/683472/23-4/identifying-host-s-nic-id.html
    5. Read and accept the terms of use, then click Generate.
    6. License is generated and sent to the account email address.
  2. Add the license file to Quartus Tools > License Setup > License File
  3. To ensure license installation, re-run the assembler
Updated 1 month ago
Version 2.0
