Knowledge Base Article
Why do I get an "Access Denied" error when attempting to start or stop the jtagserver from a Windows command line?
Description
You may get an “Access Denied" error while trying to execute some commands in the Command Prompt window when using Windows 7 or Windows Vista. You can fix this error by opening the Command Prompt window with Administrator Privileges using the following procedure:
- Click the Start button and type
cmdin the box. - Right-click on
cmdand click Run as Administrator option.
Updated 2 months ago
