Knowledge Base Article
Why do I get a System Error (SERROR) after I perform read-modify-write operations on the 32-bits ECC Peripheral registers?
Description
Due to an incorrect implementation of ECC Peripheral registers mapping, the ECC Peripheral registers listed below support read-modify-write operations for only bits [15:0]. Write operations on bits [31:16] will cause a System Error (SERROR).
Agilex 5:
ECC Address Block Group:
  • USBOTG0_ecc
  • USB1_tx_ecc
  • USB1_rx_ecc
  • USB1_cache_ecc
  • EMAC 0_tx_ecc
  • EMAC 0_rx_ecc
  • EMAC 1_tx_ecc
  • EMAC1_rx_ecc
  • EMAC2_tx_ecc
  • EMAC2_rx_ecc
  • OCRAM_ecc
Stratix 10 and Agilex 7:
  • EMAC0_rx_ecc
  • EMAC0_tx_ecc
  • EMAC1_rx_ecc
  • EMAC1_tx_ecc
  • EMAC2_rx_ecc
  • EMAC2_tx_ecc
  • USB0_ecc
  • USB1_ecc
  • NANDe_ecc
  • NANDr_ecc
  • NANDw_ecc
  • SDMMC_ecc
  • DMAC_ecc
  • OnChip_RAM_ecc
SDRAML3Interconnect Address Block Group:
  • hmc_adp_csr_ocp_slv_block
    • ECCCTRL1
    • ECCCTRL2
    • ERRINTEN
    • ERRINTENS
    • ERRINTENR
    • INTMODE
    • INTSTAT
    • DIAGINTTEST
Arria 10:
  • emac_rx_ecc
  • emac_tx_ecc
  • nandecc_ecc
  • nandr_ecc
  • nandw_ecc
  • sdmcc_ecc
  • onchip_ram_ecc
  • dmac_ecc
  • qspi_ecc
  • usb_ecc
  • usb_ecc
  • nand_ecc
Resolution
The registers listed above only support read-modify-write operations for bits [15:0].
Updated 1 month ago
Version 3.0
