Knowledge Base Article
Why do I get a Fatal Error when I compile a design using an EDIF source file?
Description
Due to a problem in the Quartus® II software version 14.1 and later, you may get a Fatal Error when compiling an EDIF netlist.Resolution
To work around this problem, generate a Verilog Quartus Mapping file (.vqm) from your 3rd party synthesis tool instead.
The problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 1 month ago
