Knowledge Base Article
Why do hardware tests fail for the F-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.3 and 23.4, hardware tests will fail when using the F-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example.
Resolution
To work around this problem, add the Quartus® Settings File (.qsf) constraints shown below to solve errors in packet transactions:
  • set_instance_assignment -name HSSI_PARAMETER "flux_mode=FLUX_MODE_BYPASS" -to rx_serial_data -entity altera_eth_tse_hw
  • set_instance_assignment -name HSSI_PARAMETER "rx_adapt_mode=RX_ADAPT_MODE_STATIC_EQ" -to rx_serial_data -entity altera_eth_tse_hw
The problem will be fixed in future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
