Knowledge Base Article
Why do F-Tile variants with PTP and Tx PTP classifier enabled within the Ethernet Subsystem Intel® FPGA IP fail to compile when using the Synopsys* VCS simulator?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.2,  F-Tile variants with PTP and PTP packet classifier enabled within the Ethernet Subsystem Intel® FPGA IP will fail to compile when using the Synopsys* VCS simulator.
This problem does not affect other supported simulators.
Resolution
To workaround this problem, add the “-ignore initializer_driver_checks” switch to the USER_DEFINED_ELAB_OPTIONS section of the run_vcs.sh file found in the <example design project name>/example_testbench directory.
This problem was fixed in version 23.3 of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
