Knowledge Base Article
Why do Ethernet links fail when using the Ethernet Subsystem Intel® FPGA IP on the Intel Agilex® 7 F-tile FHT ports at different rates?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4, Ethernet links will fail the Intel Agilex® 7 F-tile FHT ports when the FHT ports are operating at different data rates within the Ethernet Subsystem Intel® FPGA IP.
Resolution
There is no workaround for this problem.
This problem was fixed in version 23.3 of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
