Knowledge Base Article
Why do all instances have the same settings when using two or more different configurations of the R-Tile Multi-Channel DMA FPGA IP for PCI Express*?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2 or earlier, if your design contains more than one instance of the Multi Channel DMA FPGA IP for PCI Express (MCDMA IP), each configured with different IP parameter settings, the design is compiled with the same settings for each MCDMA IP instance.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 23.3.
Updated 3 months ago
