Knowledge Base Article
Why Can't We Read the Usercode After Executing an Action Followed by the Optional Procedures?
Description
A combination of executing an action followed by the optional procedures command can lead to unexpected errors.
For instance, when enabling a procedure tied to an action statement with the following command syntax:
quartus_jli.exe -averify -d do_read_usercode <file name>.jbc
In this case, an unexpected error may occur, resulting in an incorrect USERCODE output, such as:
Device #1 USERCODE is FFFFFFF
This suggests that an error may arise during the process, leading to the incorrect usercode being displayed.
Resolution
This issue occurs specifically when using the Quartus® Lite version. To resolve this, please use either Quartus® Prime Standard or Quartus® Prime Pro versions, which should prevent the error and allow for correct USERCODE reading.
Updated 3 months ago
