Knowledge Base Article
Why can't two center PLLs drive two different memory controllers with UniPHY at the bottom of a Stratix V device?
Description
The center PLLs at the bottom only have access to one PHYCLK network in the Stratix® V device.
Resolution
If you need to use center PLLs to drive two external memory interfaces, use the PLL sharing mode.Updated 2 months ago
