Knowledge Base Article
Why can't the interface clock frequency be set to a value between 137.5MHz to 149.9MHz for the PHY Lite for Parallel Interfaces Intel® Arria® 10 FPGA IP when using quarter rate mode?
Description
Due to the PLL VCO setting limitation, the PHY Lite for Parallel Interfaces Intel® Arria® 10 FPGA IP doesn’t support the frequency range between 137.5MHz to 149.9MHz when using quarter rate mode.
Resolution
There is no workaround to resolve this problem.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
