Knowledge Base Article
Why can't the back annotation command execute successfully?
Description
Due to a syntax error in AN903 2019.12.03 Section 1.3.1 Lock Down Clocks, RAMs and DSPs, when you run quartus_cdb to back annotate the Clocks, RAMs and DSPs as illustrated in the application note "quartus_cdb --back_annotate [--dsp] [--ram] [--clock] <design_name> ", you may encounter the following error:
Error (39005): Specify a project for Compiler Database Interface (quartus_cdb)
Resolution
To work around the error, use the following command:
quartus_cdb <design_name> --back_annotate [--dsp] [--ram] [--clock]
This syntax error is fixed starting with the updated 2020.03.23 AN903 documentation.
Updated 1 month ago
