Knowledge Base Article
Why can't I refresh the Nios® V processor BSP settings in the Platform Designer after editing the Nios® V processor BSP via the command line?
Description
The Platform Designer in the Quartus® Prime Pro Edition Software version 21.3 and later does not support refreshing or reloading the Nios® V processor BSP that is modified externally, for example, via the command line from active Platform Designer sessions.
Resolution
To work around this limitation, close and re-load the Platform Designer system to load the externally modified Nios® V processor BSP settings.
This problem is scheduled to be resolved for a future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
