Knowledge Base Article
Why can't I pack two independent 18x18 multipliers into single Arria® V DSP block?
Description
Under certain conditions, the Quartus® II software may not be able to pack two independent 18x18 multipliers into the same Arria® V DSP Block.
Resolution
To work around this issue, add the following line into your quartus.ini file under the project directory:
fsac_ff_enable_mac_scan_chain_packing=OFF
If you do not already have a quartus.ini file, use the text editor and create this file in your project directory, then add the above line.
This problem is fixed in Quartus® 13.1.
Updated 3 months ago
Version 2.0
