Knowledge Base Article
Why can't I generate the Arria 10 device SerialLite III design example in Quartus Prime Standard editions 16.0, 16.1 and 17.0?
Description
Due to a problem in the Quartus® Prime Standard edition software versions 16.0, 16.1 , and 17.0, you may not be able to generate the Arria® 10 device SerialLite® III design example.
The design example generation may hang with the following information in the dialog box:
seriallite_iii_a10_0: Generating testbench components for simulation
Info: seriallite_iii_a10_0: Generating simulation kick-off scripts
Info: seriallite_iii_a10_0: Generating tcl files for QSYS generation
Resolution
To fix this problem install the Quartus Prime Stratix® V device package.
This problem will be fixed in a future version of the Quartus Prime software.
Updated 3 months ago
