Knowledge Base Article
Why can't I generate F-Tile Multi-Channel DMA Intel® FPGA IP for PCI Express* example design in the Intel® Quartus® Prime Pro Edition Software version 23.2?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.2, you might see an example design generation failure when using 1x4 Endpoint mode for F-Tile Multi-Channel DMA Intel® FPGA IP for PCI Express*.
Resolution
To work around this problem, uncheck the 'simulation' option to generate an example design.
This problem was fixed in version 23.3 of the Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
