Knowledge Base Article
Why Arria® 10 SGMII Reference design in rocketboards.org doesn't work property?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software versions, you might see any errors with Arria® 10 SGMII Reference design on Arria® 10 SoC.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition software version 20.3 or later, follow the steps below
1) Open attached script (run-cal-slack.tcl)
2) Edit instance name for GMII to SGMII converter in the run_cal_slack.tcl as below
       set EMAC0   sgmii_1
       set EMAC1    sgmii_2
       set EMAC2    null
       set EMAC3    null
The script can support up to 4 ports. A variable should be set ‘null’ if not needed.
3)    Launch Timing Analyzer
4)    Run updated script from a menu ( Script > Run Tcl Script )
5)    End of the workaround if the script returns 0.
6)    Add two constraints below to top sdc in your project such as ghrd_timing.sdc.
     set_net_delay -min 1.2 -from [get_registers {*|altera_gts_clock_gate:u_pcs_tx_clk_gated|en_flp}] -to [get_pins -compatibility_mode {*|u_pcs_tx_clk_gated|clk_gated|combout}]
     set_net_delay -min 1.2 -from [get_registers {*|altera_gts_clock_gate:u_pcs_rx_clk_gated|en_flp}] -to [get_pins -compatibility_mode {*|u_pcs_rx_clk_gated|clk_gated|combout}]
7)    Recompile your design.
8)    Go to 3 if a timing is met.
This problem is currently scheduled to be resolved in a future release of the Intel® Quartus® Prime Pro Edition software.
Updated 3 months ago
Version 2.0
