Knowledge Base Article
Why ares some IP Cores incorrectly reported in the IP Upgrade dialog?
Description
Due to a problem, Quartus® Prime Pro Edition IP Cores generated by the v16.1 versions of software may report an incorrect IP Variant Type and incorrect release note link in the IP Upgrade table prior to running synthesis.
Resolution
To correct this issue, simply perform IP Upgrade on any affected IP Core variant.
This problem has been fixed starting in software versions 17.0 and above.
Updated 27 days ago
