Knowledge Base Article
Why aren't my delay chain values back-annotated correctly?
Description
Due to a problem in the Quartus® II software version 12.1 and later, back-annotation of delay chain settings does not work correctly. This problem affects designs targeting Stratix® V, Arria® V, and Cyclone® V devices.
Resolution
To work around this problem, back annotate delay chain settings using a Tcl script such as the one below. This Tcl script uses D5 delay chain settings as an example.
load_package chip_planner
project_open <project_reversion_name>
read_netlist
set nodes [get_nodes -type io]
foreach_in_collection node {
    set name [get_node_info -info name -node ]
    set d5 [get_node_info -info "D5 Delay Chain" -node ]
    if { != 0 } {
        set_instance_assignment -name T9_DELAY -to
project_close
Updated 2 months ago
Version 2.0
