Knowledge Base Article
Why aren’t the tx_polinv and rx_polinv ports available when using the transceiver Native PHY IP for Intel® Arria® 10 and Intel® Cyclone®10 devices in Enhanced PCS mode?
Description
The transceiver Native PHY Intel® Arria® 10 and Intel® Cyclone® 10 FPGA IP in Enhanced PCS mode does not have tx_polinv and rx_polinv ports.
Resolution
You can use the Gearbox Enable RX data polarity inversion and Enable TX data polarity inversion settings to implement static polarity inversion.
You can implement dynamic polarity inversion by reconfiguring the PHY with different Gearbox Enable RX data polarity inversion and Enable TX data polarity inversion settings.
Updated 10 months ago
