Knowledge Base Article
Why are there two different setup relationships for timing paths to the altera_reserved_tdo port in the TimeQuest Timing Analyzer?
Description
Due to a problem in the Quartus® II software version 12.0 SP1 and later, you may see two different relationships for timing paths to the altera_reserved_tdo port. This problem occurs in Arria® V, Cyclone® V and Stratix® V designs that use the SignalTap™ II Logic Analyzer and manually constrain the altera_reserved_tdo port.
The TimeQuest™ Timing Analyzer incorrectly reports timing paths from both the rising edge and the falling edge.
Resolution
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
