Knowledge Base Article
Why are there timing violations on the *pld_fpll_shared_direct_async_out_hioint[2] clock domains within the Agilex™ 7 device F-Tile PMA/FEC Direct PHY Multirate FPGA IP?
Description
Due to a problem with the Agilex™ 7 device F-Tile PMA/FEC Direct PHY Multirate FPGA IP in the Quartus® Prime Pro Edition Software version 22.4 and earlier, you might see timing violations on the following clock transfers:
From Clock:
*_auto_tiles|*__reset_controller_src_divided_osc_clk
To Clock:
*_auto_tiles|*|hdpldadapt_tx_chnl_*|pld_fpll_shared_direct_async_out_hioint[2]
Resolution
Violations between these clock domains are invalid and can be avoided using a set_false_path command.
This problem is scheduled to be resolved in a future release of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
