Knowledge Base Article
Why are there periodic glitches on the transceiver Tx pins when using F-tile PMA/FEC Direct PHY IP in GPON mode with single-width transfer?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3 and earlier, when you instantiate PMA/FEC Direct PHY IP in GPON mode with signal-width transfer, you may see periodic glitches on the transceiver Tx pins.
Resolution
To work around this problem in hardware, perform the following steps:
- Navigate to <your ip directory>/.
- Locate dphy_f_tx_dsk_gen.sv and change the following lines:
From
genvar l;
for(l=0;l<LANES;l=l+1) begin:lane
assign o_data[l*80+:80] = DOUBLE_WIDTH_ON ? {i_data[l*80+79], tx_dsk_pulse, i_data[l*80+:78]}
: {i_data[l*80+79 : l*80+37], tx_dsk_pulse, i_data[l*80+:36]};
end : laneTo
genvar l;
: {i_data[l*80+79 : l*80+37], 1'b0, i_data[l*80+:36]};
end : lane
This problem has been fixed starting from the Quartus® Prime Pro Edition Software 24.1.
Updated 1 month ago
