Knowledge Base Article
Why are there data errors on the HPS LPDDR2 interface?
Description
Due to a problem in the SoC EDS software version 16.0 and earlier, data errors may be seen on Cyclone® V SoC and Arria® V SoC HPS SDRAM interfaces in LPDDR2 mode.
Hard or soft LPDDR2 interfaces in FPGA logic (non-HPS) are unaffected.
Resolution
Follow the steps below to work around this problem in the SoC EDS Software version 16.0 and earlier.
This workaround, manually sets pessimistic values for read-read and write-read turnaround for the Altera HPS SDRAM controller in LPDDR2 mode, which may reduce performance.
1. Open the following file from your HPS Preloader BSP:  u-boot-socfpga/arch/arm/cpu/armv7/socfpga/sdram.c
2. Add the workaround code below after line 1345 (u-boot 2013):
            COMPARE_FAIL_ACTION
#endif
    /***** START workaround to Set read to read and read to write delay *****/
    debug("manually configuring read to write turnaround delays \n");
    register_offset = 0x501c;
    /* Read original register value */
    reg_value = readl(SOCFPGA_SDR_ADDRESS register_offset);
    reg_value = 0x44400000;
    if (sdram_write_verify(register_offset, reg_value) == 1) {
    status = 1;
    COMPARE_FAIL_ACTION
    /***** END  Workaround*****/
    /* Restore the SDR PHY Register if valid */
      if (sdr_phy_reg != 0xffffffff)
      writel(sdr_phy_reg, SOCFPGA_SDR_ADDRESS
3. Regenerate the software preloader by running make clean and then followed by running make
This problem is scheduled to be fixed in a future release of the SoC EDS Software.
Updated 1 month ago
Version 2.0
