Knowledge Base Article
Why are the stable and resolution valid bits within the Status register of the Clocked Video Input II Intel® FPGA IP stuck at 0?
Description
Due to a problem with the Clocked Video Input II (4K Ready) Intel® FPGA IP in Intel® Quartus® Prime Software version 17.0 software, you may observe the above problem if you are using embedded synchronization mode.
Resolution
There is no workaround for this problem.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
