Knowledge Base Article
Why are the Output Enable/Disable Times for a bus the minimum value for all bits of the bus?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 19.1, the Output Enable/Disable Times reports the minimum delays instead of displaying the maximum value for bus bits. This problem occurs when targeting Intel® Stratix® 10 devices.
Resolution
To work around this problem, expand the aggregated data bus bits and identify the maximum delay value manually.
This problem was fixed starting with the Intel® Quartus® Prime Pro Edition Software version 19.3.
Updated 2 months ago
